2016 Corvette stored over winter about 4 months. Car battery is full up as it’s been on the charge maintainer all winter. The key fob hung up about 3 feet away from Corvette. Tried to start dash says no fob detected. Put fob in window in steering column and car started right up. Other fob was same issue. Changed the batteries in both fobs. New batteries on volt ohm meter reads 3.26 volts...good. Still no fob operating anything. Yes the battery’s are installed correctly and the seal is not on battery. Tried pressing both lock/unlock at same time still no go.
What’s wrong?
What’s wrong?
