In the 1967 L68 427ci/400hp, was the 3904351 cast a 2-bolt or 4-bolt? Thanks?
2-bolt or 4-bolt in a L68
1967 Corvette L68 convertible https://bit.ly/2yykRW7
1967 GTO 400 convertible
1968 Camaro 396 SS/RS convertible
1969 Mach 1 R-Code Cobra Jet
1978 VW Beetle convertibleTags: None- Top
Re: 2-bolt or 4-bolt in a L68
Thank you!1967 Corvette L68 convertible https://bit.ly/2yykRW7
1978 VW Beetle convertible- Top
Eric,
Your L68 was machined with 2-bolt main bearings. Casting #3904351 was used for both 2-bolt and 4-bolt applications. Original machining above the oil filter boss identifies a 2 or 4 bolt configuration.
Dave
2 and 4 bolt ID.jpgJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Dave, great info, thanks!!1967 Corvette L68 convertible https://bit.ly/2yykRW7
