installing door weather striping - NCRS Discussion Boards
  • Mel S.
    • August 31, 1992
    • 264
    Any good suggestions on how to apply the weather striping on the doors of a c2. Start from the hinge side? The lock side? I know that the adhesive is "non" forgiving. Once on good luck. I do not want to start adhering it and then when i get to the other side have it too long or short.
    Mel
  • Mike M.
    • May 31, 1974
    • 8409
    Re: installing door weather striping
    originally the two ends of the W/S met about half way back on the bottom of the doors. mike
    • John F.
      • March 23, 2008
      • 2424
      I have never done it, but I would tape it on with blue painters tape, and then slowly go around with the cement. Just my two cents.
      • Jim D.
        • 2885
        That's true on coupes but convertibles have formed ends and are a bit tricky to get in the proper position.
        • Robert W.
          • June 28, 2018
          • 134
          For a general "How to" look on-line for a video by Steele Rubber Products "How to glue weatherstrip" showing the proper glue application. A lot of people just slather 3M adhesive on and press the WS on until it stops moving which results in a mess. I usually pre-fit the WS and put a piece of tape at the halfway point so I'm only worrying about aligning 1/2 at a time.
          • Mel S.
            • August 31, 1992
            • 264
            Thanks i like this approach
            Mel
            • Gary J.
              • April 1, 1980
              • 1246
              Does anyone have a clear picture of the way the weatherstripping is installed?
              • Perry M.
                • January 1, 1977
                • 325
