'67 Clutch Assembly Washer Sizes - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3645
    I'm going to pull the pin on the clutch rod at the assembly under the dash to install the two washers that are supposed to be there. I know that there was a running change and a thicker washer was added to the outer side of the pin. What is the thickness of the two washers. I thought I had read somewhere that the thin washer (3834560) was .013" and the thicker washer (3754153) was .018". I want to be sure I have the two correct washers in hand before crawling under there to do this. Thanks in advance.
    Leif
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: '67 Clutch Assembly Washer Sizes
    Leif,
    Google the part #'s and you may find the size info. I think the inside washer was the same as the exhaust manifold washer.
      • 43247
      Leif------
      The GM #3754153 was 0.34" ID, 0.74" OD, and 0.13" thick. Phosphate finish
      The GM #3834560 was 0.34" ID, 0.69" OD, and 0.19" thick. Phosphate finish.
      • Leif A.
        • August 31, 1997
        • 3645
        Originally posted by Timothy Barbieri (6542)
        Leif,
        I'll see what I can find. thank you
        Leif
        • Leif A.
          • August 31, 1997
          • 3645
          Leif------
          Joe,
          Exactly the information I was looking for. As always, thank you for sharing your vast amount of knowledge...truly appreciated.
          Leif
            • 43247
            Joe,
            Leif------
            By the way, the GM #3834560 is still available from GM.
            • Leif A.
              • August 31, 1997
              • 3645
              Leif------
              Thanks Joe!
              Leif
              • Timothy B.
                • April 30, 1983
                • 5196
                Leif------
                Joe,
                I have a sealed bag of five 3754153 washers and the ID looks more like .380 to allow a 3/8" bolt to pass through.
                Am I mistaken or did you make a typo?
                  • 43247
                  Joe,
                  Timothy------
                  As a matter of fact, the spec I found for the ID has it at 0.40" but I thought that was incorrect so I foolishly took the liberty of revising it to the 0.34". I just could not see how GM would specify a washer designed for a 3/8" bolt/pin to be used on a 5/16" pin. I still do not understand why they would do that.
