C2 Upper Dash Sound Deadener - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 935
    Can anyone recommend an adhesive to install the upper dash sound deadener. I have some 3M Super 77 and was wondering if this would work well. Should I try to spray both the car and the sound deadener before putting them together ? Should I use contact cement instead ?
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: C2 Upper Dash Sound Deadener
    The adhesive you have will work just fine..... you can coat both just to be sure.
