Kick Panel Identification - NCRS Discussion Boards
  • Steve P.
    Infrequent User
    • February 8, 2016
    • 16
    I'm trying to identify two interior kick panels. So far the best bet is they are out of a 1972. The inside panel markings are R 471910 R.H and L 471909 L.H.. The right hand panel has a gP marking inside a circle. The left hand panel has a stamped G.P. on the same line as the stamped number.
    • 43259
    Re: Kick Panel Identification
    Steve------
    These part numbers did not even exist in 1972. These covers were used on 1978-82 and became SERVICE for 1968-77 in January, 1982. The original covers for 1972 were GM #3964113 and 3964114.
    • Steve P.
      Infrequent User
      • February 8, 2016
      • 16
      Thanks for the info. I guess service means they will fit. I knew they were wrong for my 69 and I have replaced them with beleived to be correct ones.
        • 43259
        Steve-----
        Well, if by "wrong" you mean "incorrect as to originality" the answer is definitely yes. As far as functionality goes, they are fine.
        The original panels for a 1969 were GM #3930495 and 3930496.
