Transmission Speedometer Gear
Re: Transmission Speedometer Gear
I installed the correct gear (21 tooth) into the housing and tried to spin it with a tach cable. It did not spin which told me it is engaged. When I did the drill test, the speedo, the odometer and tripometer all moved. I think I'll put the car on jack stands and try that method. Maybe the gears are engaging just enough so that I can't spin the cable by hand. Maybe under power, it won't engage enough to spin the cable.- Top
Latest Update!
I put the car up on jack stands and installed another speedometer cable outside of the car so that I can watch it spin (hopefully!). Well it did spin with the correct red driven gear. So I think the installed cable itself is too short! So at least it's not in the transmission. I will pull the cluster forward and install a new cable with the correct length, or at least measure the one that's in there.
I'm trying to find out the correct cable length for my 63 with 3:55 Gears. One post I See is 56 1/8".Last edited by Gerald C.; October 30, 2021, 12:22 PM.- Top
As I commented previously, in my Paragon speedo cable for a 67 the inner cable was 4/10's of an inch too short for the cable housing (comparing its projection from the housing with my OE cable assembly). I got a universal speedo cable repair kit and simply cut an inner cable 4/10's longer than the Paragon piece and inserted it in the Paragon housing. That fixed it without having to pull the dash out and replace the whole housing.- Top
Here's an update: As I mentioned in my previous post, the NAPA cable worked/spun from the transmission while the car was running on the jack stands and the cable end in my hands. Then I tested the installed cable, fitting and driven gear into a drill and ran the drill in reverse and the speedometer worked. Then I re-installed the cable that's in the car and spun the tires and the speedometer didn't work! I don't get while the drive gear runs the NAPA speedo cable and the drill runs the installed cable, but when placed in the fitting with the correct drive gear, the speedo doesn't work. Thoughts on my conundrum??
Okay....my next step will be to replace the inner cable which is probably too short. Thoughts on which vendor sells the correct cable? Dr. Rebuild has been highly recommended. Others???Last edited by Gerald C.; October 31, 2021, 04:41 PM.- Top
Another update! The cable reaches out about 1 1/2" into the driven gear. Still no speedometer. I placed a small screwdriver slightly into the driven gear while it's inside the housing inside the transmission and it didn't turn which tells me its engaged in the drive gear. Also, the drive gear is centered on the hole where the housing goes. I just installed a 22 tooth versus a 21 tooth driven gear tonight to see if that makes and difference. More to follow......I'm running out of options here!- Top
Gerald------Another update! The cable reaches out about 1 1/2" into the driven gear. Still no speedometer. I placed a small screwdriver slightly into the driven gear while it's inside the housing inside the transmission and it didn't turn which tells me its engaged in the drive gear. Also, the drive gear is centered on the hole where the housing goes. I just installed a 22 tooth versus a 21 tooth driven gear tonight to see if that makes and difference. More to follow......I'm running out of options here!
What color 22 tooth driven gear did you install?In Appreciation of John Hinckley- Top
Joe,
I don't know what the original driven gear was in the car. However, the 21 tooth red gear isn't working. I just don't know where else to look or deal with to get this speedometer to work! I took the car out the other day after restoration and the speedometer was working, then stopped. Come to find out, the cable to the back of the cluster came out. I put it back in and made it tight. Then the speedometer didn't work. The cable is inserted properly as proven by the drill test I did yesterday.
Thanks for your comments and future advice.
Jerry- Top
Gerald-------
More questions:
Is the transmission original to the car? M-20 or M-21?
Is the differential original to the car and what is its gear ratio?In Appreciation of John Hinckley- Top
Jerry------
Well, it would have to be 3.55:1!
The simple answer would be that your transmission has a GM #3708145 speedometer DRIVE gear (1.74"OD) installed. This gear will mesh only with 22 tooth (green) to 25 tooth DRIVEN gears. If an 18 to 22 tooth (silver) DRIVEN gear is installed, it will not mesh properly with the DRIVE gear and the speedometer will not operate or operate erratically. The 1.74" DRIVE gear requires 22 tooth (green) to 25 tooth DRIVEN gears.
The problem is that GM says that your 1963 3.55:1 application used the GM #3708144 DRIVE gear (1.85" OD) and a 21 tooth DRIVEN gear.
However, some other 3.55:1 applications did use the 3708145 DRIVE gear and 22 tooth (green) DRIVEN gear. The 3.55:1 rear gear is "right-on-the-cusp" as far as required speedometer DRIVEN gear goes and whether a 21 or 22 gear is needed also determines which DRIVE gear is installed (and the 22 tooth silver DRIVEN gear did not exist in 1963).
So, given what you've found, I'd have to surmise that your transmission has the GM #3708145 (1.74"OD) DRIVE gear installed and, thus, can use only 22 tooth (green) through 25 tooth DRIVEN gears.
If you've had this car for awhile and the speedometer did once operate properly, what DRIVEN gear did it have installed then?
Also, I'd be curious as to how accurate the speedometer is now with the 22 tooth (green) DRIVEN gear installed? You can accurately check this with a portable GPS.In Appreciation of John Hinckley- Top
I think the 22 tooth green gear was listed for both the the 3.55 and the 3.70 rears, so great accuracy was not expected and his tires may have the greater influence.- Top
