70 LT1 help - NCRS Discussion Boards
70 LT1 help
+ More Options
Posts
  • Dennis D.
    • March 1, 2000
    • 1071
    70 LT1 help
    Been correcting a few running issues now that I've been home for awhile. Installed the freshly rebuilt carb, Big improvement. Compression, leakdown checked out fine.
    Moving on to the distributor, I believe, just by looking, at least the cam weight is wrong. and vacuum can. (have the correction for that). 540 would indicate 40* mech advance, the spec on the 1111491 dist is 26* mech.
    Does anyone with a 70 LT1 have a pic similar to what I posted here, show the advance number stamping? Or know what their advance number stamping is? Thanks in advance.
  • Ed H.
    • November 19, 2015
    • 192
    Re: 70 LT1 help
    Not at my fingertips. I will get to it, if someone else doesn't first.
    • Dennis D.
      • March 1, 2000
      • 1071
      Re: 70 LT1 help
      Thanks Ed greatly appreciate
      • Leonard M.
        • September 7, 2009
        • 236
        Re: 70 LT1 help
        Dennis the one on the left is a 491 I used to own.
        • Dennis D.
          • March 1, 2000
          • 1071
          Re: 70 LT1 help
          Leonard. Do you have a pic with the weights off so the stamped number is visable on the can weight?
            • 43282
            Re: 70 LT1 help
            Dennis-----
            The original rotating pole piece for your application was GM #1967928. This pole piece was supposed to have been stamped "536".
            • Dennis D.
              • March 1, 2000
              • 1071
              Re: 70 LT1 help
              Dennis-----
              Joe..
              Yes my searching keeps bringing me back to that number. My problem is the spec for the 1111491 lists a max centrifugal advance of 26 degrees. Unless the "536" has a different translation than 36 degrees, not sure about that part number.
              Thought getting same actual numbers from known correct units might shed some light. Thanks.
              • Dennis D.
                • March 1, 2000
                • 1071
                Re: 70 LT1 help
                also finding 2 different mainshafts. The pic of mine and the pic of Leonards appear to be the same. I also get this one,(top pic), when I check what the venders have as being Hi perf.
                • Leonard M.
                  • September 7, 2009
                  • 236
                  Re: 70 LT1 help
                  Sorry Dennis, I do not have any other pictures and the distributor is gone.
                  My pictures showing the distributor on the right is a 1112038 '71 LT1 distributor. The top looks to be the same as your "vendor high performance"
                  • Dennis D.
                    • March 1, 2000
                    • 1071
                    Re: 70 LT1 help
                    No problem Leonard. Your pics are very helpful. Thanks
