Holley 2818 question 1964 365hsp - NCRS Discussion Boards
  • John R.
    • November 1, 2005
    • 433
    Attached are 2 photos. The first shows a part on a very early Aug 1963 2818 designated by a red circle. The second photo shows the same part, different configuration, on a 2818-1 dated April 1965 circled in green. Are these parts supposed to be different based on the different years of production or has someone changed the original configuration on one of the carbs? My main focus is to restore the early Aug 1963 carb correctly.
  • John R.
    • November 1, 2005
    • 433
    Re: Holley 2818 question 1964 365hsp
    I have figured this one out. Both parts are the same, but Bubba decided to spread both threaded tabs for the adjustment screw on the red circled one. So, I have another question. What chock housing does the early 2818, Aug 1963, use? Both of these carbs had a different chock housing. The part #'s are 34R-1523 B and 34R-1945 B. Which is correct for the early 2818? Thanks in advance for any help!
