1965 Brake/clutch pedal mounting bracket - NCRS Discussion Boards
    • December 1, 2005
    • 176
    I'm a new user of the forum and am currently in the process of restoring my 1965 Fuelie Coupe #5248 (Dec. '64 build). It appears that the brake/clutch pedal mounting bracket that mounts to the firewall is painted black as are the pedal arms. Is this correct? If so, is it flat or satin black. Thanks for any info.
  • Mark L.
    • 559
    Re: 1965 Brake/clutch pedal mounting bracket
    Terry, sounds like a neat Corvette. Have you looked at the latest edition 65 Technical Guide. I'd bet the info is there along with a lot more.
    • Mike M.
      • May 31, 1974
      • 8376
      i use semi gloss black but the upper 1/4 of each pedal arm was not painted. btw, i have 65 FI vin 5094,a white/blue vinyl coupe sold new at harry mann chevy in so cal. i got two other 65 FI's so if you need help, email me( since the 65 team leader is a bit touched). welcome to NCRS. mike mccagh
      • Murray S.
        • May 31, 1990
        • 72
        Terry: Mike is correct; the current JG states: both brake and clutch pedals are painted semi-gloss black up to the actuating rods.
        Murray
        • Don H.
          Moderator
          • June 16, 2009
          • 2244
          Hello Terry
          welcome to the TDB, after all these years. Good to have you. Is your 65 Maroon? And by chance does the plenum have vin stamped on 4 times?
            • December 1, 2005
            • 176
            Don, my corvette color is maroon. The plenum stamp was a double strike. John DeGregory restored the unit some years ago. The car/unit is listed in Noland Adams' book. Thanks.
            • Don H.
              Moderator
              • June 16, 2009
              • 2244
              I will give it a look in Noland V2. It is also in Jim Gessner's 65 FI Registry. Look for Jim to get in touch for an update.
                • December 1, 2005
                • 176
                Don, Just sent Jim an email with info an hour or so ago. Expect he may contact me. Thanks again.
                • James G.
                  • May 31, 1976
                  • 1556
                  TERRY, would like to get update on this car. info i have must be incorrect, or needs update
                  • Chris D.
                    • July 31, 1990
                    • 27
                    Attached are some pictures of an original set from 1965 FI coupe 6210 currently under restoration. If you need more let me know.#1.jpg#2.jpg#3.jpg#4.jpg#5.jpg
                    • Stephen B.
                      • April 1, 1988
                      • 876
                      I did not realize how close your 65 FI was to mine in VIN number. Mine is # 5047.
