Reproduction clip quality - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 941
    I have been restoring a C2 and have been having issues with spring steel reproduction clips not being very good. Yesterday I was installing the metal clips that attach the headlight wiring to the body and none of the clips would bite. I also couldn't get the plastic clips connected to the wiring harness to stay in the hole. I tried re-bending the tangs but that didn't help. I ended using JB Weld to install all of them so I hope that will work.
    I had similar issues with the brake line fame clips. The clips would not lock into the frame very tightly.
    If I had good original clips I always use them over reproductions.
    Anyone else have these type of issues ?
  • Don H.
    Moderator
    • June 16, 2009
    • 2274
    Re: Reproduction clip quality
    Mark
    you could buy all those clips, used originals, from major Driveline advertiser David Sokolowski out in South Gate, CAL. He has buckets full.
    • Mark P.
      • May 13, 2008
      • 941
      Thanks Don. I didn't realize he had them. My purchases with David have all been $250 plus. Wasn't sure he did smaller orders.
      • Don H.
        Moderator
        • June 16, 2009
        • 2274
        I send him a list by email, including photos if necessary, and within about a week I will get a call, or an email back with pics of the pieces he pulled out. He is sending me two screws now. I try not to buy that little normally, but so far he has not turned me down for a job "too small".
