Harmonic Balancer - NCRS Discussion Boards
Harmonic Balancer
  • John C.
    • September 30, 2001
    • 130
    Harmonic Balancer
    On a cold start I hear noise coming from this lower area sounds like a fan hitting the fan guard, but no I checked the noise is very loud but stops after a few minutes how does the balancer get lubrication? Could this be a bad bearing? THanks
  • Terry D.
    • May 31, 1987
    • 2691
    Re: Harmonic Balancer
    The balancer doesn't get lubrication, if it sounds like fan on metal I doubt it is a bearing, they usually don't go away. Could you have someone else start the car and listen? A long screwdriver makes a fair stethoscope. Is it a ticking sound or a scraping sound? Try disconnecting the fan belt and see if the noise happens. While you have fan belt off check harmonic balancer tightness. Let us know what you find out.
    • Michael H.
      • December 1, 1987
      • 729
      Maybe a water pump going bad or a clutch fan.
      Mike
      • Mark E.
        • April 1, 1993
        • 4542
        Removing the belt to troubleshoot is a good start. Check torques on all belt/pulley/fan fasteners.
        A failing balancer isn't a noise maker unless it's so far gone it's hitting something (timing marker, timing cover). That should be easy to see.
        Could it be a belt squealing?
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
