Minor Popping noise from exhaust - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Today I noticed a occasional, but minor, popping from the right side exhaust while the engine was running at idle.
    Any thoughts as to what is going on?
    • 43293
    Re: Minor Popping noise from exhaust
    Jerry-----
    One possibility would be a slightly malfunctioning diverter valve. Easy to check. Disable the pump (remove the belt) and seal off the diverter valve vacuum source from the carb. If the popping ceases, you've found the problem. If not, it's something else.
