67 Corvette Trim Tag - NCRS Discussion Boards
  • Rick C.
    • September 16, 2008
    • 22
    Has anyone ever seen a trim tag on a February 67 built car with no period after the word Corp?
    • 43247
    Re: 67 Corvette Trim Tag
    Rick------
    I have not although that certainly does not mean that some might have been this way.
    However, the thing that would make me very suspicious is that this part of the trim tag was part of the BLANK. I could understand this kind of discrepancy in the embossments on the tag that were done at St. Louis or Ionia but I would not expect it on the BLANK.
    • Jack M.
      • March 1, 1991
      • 1177
      Rick- Are you certain itz just not a bad photo, and the period is somehow obscured... have you examined the tag in person?
      Here are several 67 Trim Tag images (from the web) in a composite... on occasion, the last period appears different than the first.
      In the top three images, I can barely make out that last period... and for the last image, I don't see anything at all.
      • Rick C.
        • 22
        Hi Jack
        I will have someone go to the car and check maybe take a better photo.
        • Tony S.
          • July 15, 2009
          • 39
          In this photo you can plainly see the DOT or PERIOD after the Letters DIV. If one were to run their finger along the embossed letters you could surely feel if the DOT was there or non. I cannot see the DOT or Period after the word Corp and my Feb. car has the DOT or Period. Since we are on the topic,
          my collection of trim tag photos also show that there are tags with the DOT or Period after the letters STD Before January and not after. This my view and opinion.
          • Patrick B.
            • August 31, 1985
            • 2003
            Green was a popular color in 1967, but it fell from favor. Lots of red and black cars started as green and many were given fake trim tags. But I don't think there is a trend to use fake trim tags to make green (code 983) cars. This car certainly deserves the benefit of the doubt regarding periods.
            • Gary S.
              Super Moderator
              • February 1, 1984
              • 460
              Yes, go take another picture. I blew the picture up and I think the period is there...there is an image in the exact place the period is suppose to be, it just does not show up as plainly as it should probably due to angle, lighting, camera quality or....
              Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
                • 43247
                Tony-----
                The "STD" was embossed at St. Louis or Ionia. As I mentioned, I could more understand variations for these embossments.
                • Owen L.
                  • September 30, 1991
                  • 882
                  Tony-----
                  Not intending to side track this topic...
                  Do we know why the alignments of the cars' information is so poorly placed within the tag layout? I would assume a jig was used but why didn't "they" set it up more carefully? Was there some sort of limitation with the stamping process?
                    • 43247
                    Owen------
                    If I remember correctly, these were done on a version of an old-fashioned "address-o-graph" machine. Of course, they were done individually for each car by assembly line personnel. The machine may have been worn and/or the line operator making the tag not too careful. I highly doubt that perfection for these was a really high priority. As long as they conveyed the proper information, that was fine.
                    The blanks, on the other hand, were mass produced. Thousands of blanks were likely made from the same die set up. So, care was taken for the initial set-up and and any "miscreants" discarded prior to shipping to the assembly plant. By the way, I believe these particular blanks were used only for Corvette since tags for all other GM cars were embossed "Body by Fisher". Corvette was the only platform I know of that was "Body by Chevrolet"
                    • Tony S.
                      • July 15, 2009
                      • 39
                      Do we all agree that the mass produced blanks that were made from the same die set-up had pre-stamped information and that the letters and periods all appeared on every Tag including the word CORP. which is part of the pre-stamped information?
                      • Vinnie P.
                        Editor NCRS Restorer Magazine
                        • May 31, 1990
                        • 1573
                        There is a very comprehensive Trim Tag book for sale right from the NCRS store...should answer all your questions
                        National Corvette Restorers Society! NCRS Authentication Library Vol 1 1963-67 Corvette Trim Tags - With Exception Control Letter Code Listings and Sequential Photographic Analysis By Al Grenning and Roy Sinor with generous assistance from Bill Calorico, Nick Culkowski and the NCRS Team Leaders. Buying or restoring a 1963-1967 Corvette? You need this book! This book provides the means by which original GM issued Corvette trim tag
                        • Jack M.
                          • March 1, 1991
                          • 1177
                          I found a larger version of this trim tag online... and enlarged, I'm seeing a 'shadow' dot (similar to a few images in the composite I posted earlier).
                          Again, it can all be an optical illusion... hope you can obtain a better photo.
                          • Owen L.
                            • 882
                            Owen------
                            Thanks Joe. If I were the employee running the stampings, I guess the compulsive-ity of my nature would have forced me to try to get the address-o-graph better aligned! Maybe the designer of the tag didn't anticipate the need for the body date at the top (which seems to force the following information downward.) Which begs the question as to why the date isn't stamped as a bottom line? And why doesn't the date have its own call out identifier? (Did I mention I'm a tad anal compulsive? -- especially about graphic design things)
                            I never thought about the uniqueness of the Corvette's body affecting that. I fondly recall our family's brand new '68 Bonneville station wagon and the "Body by Fisher" logo.
                            (not our car but similar)
                            • Tony S.
                              • July 15, 2009
                              • 39
                              How about this Tag then?67- Discussion Tag Compare-2.jpg67- Discussion Tag Compare.jpg
