1965 Fresh air and rear blower vent cable under dash routing question - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2655
    So the '65 AIM C60 section sheet E7, view B notes to route the rear vent cable over the steering column and under the parking brake which I have done.
    My question is this, the driver's side fresh air vent cable routing shows that it should be routed over and under the hood release cable where they are bound together with the metal clip. I know this is possible on a non a/c equipped car but on a car with a/c I can't see this to be possible with the a/c ducting located under the dash. Right now, I have the driver's side cable route under the a/d duct then up and over steering column bracket. Can someone with give me some guidance as to whether this is correct or not. The way the cable is routed over to the vent, there is no way it comes close to being able to be clip to the hood release cable.
    James West
