65 fuse box - NCRS Discussion Boards
65 fuse box
  • John F.
    • March 23, 2008
    • 2418
    65 fuse box
    With the battery connected are all the fuses in the fuse holder hot?
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 65 fuse box
    Check the wiring diagram in your AIM. Not all fuses are hot all the time.....
    • John F.
      • March 23, 2008
      • 2418
      Re: 65 fuse box
      My 65 AIM has not arrived yet.
        • 6955
        • John F.
          • March 23, 2008
          • 2418
          Re: 65 fuse box
          Thank you Ed. Just what I was looking for.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11363
            Re: 65 fuse box
            John I have a 1965 wiring diagram pdf but too big to upload here. PM me your email address and I send it over if you'd like.
            To add to Edwards info, note that the 2 Radio and Heater fuses will not have source power unless key is RUN or ACC, nor will GAUGES or Directionals fuse. Anything on BLACK/ORANGE(Courtesy lamps, Glove Box lamp, Stop Lamps, Clock, Optional Hazard Flashers) will have power at all times.
            Rich
            PS I added some pics showing the backside of a panel to show how the fuses get their source voltages......
            Below is a 1966 panel, which except for some colors, IIRC is same as 1965(e.g. 66 Pink is Blk/Pink for 65).
            Note the 2 bottom fuses sourced from RED outer side wires. Those always powered, key OFF or any position.
            Bottom fuse is the COURTESY, etc fuse.(66 ORG is Blk/Org for 65)
            2nd from bottom is the BROWN feed to the Headlight switch to power the Tail lamp circuit and dash PANEL lamps fuse.
            The GREEN wire(3rd from bottom) is the PANEL lamps fuse(output GRAY wire) only powered when Headlight switch on(either detent), and TAIL LAMPS fuse(2nd from bottom) is powered.
            The next 2 up are the BROWN source for Radio & Heater. Powered RUN or ACC
            The top fuse is the GAUGES fuse. Powered RUN or ACC
            Here's a 1965 panel and appears the fuses are in the same physical configuration as 1966.
            • John F.
              • March 23, 2008
              • 2418
              Re: 65 fuse box
              Thank you Richard.
