Fuel pump - NCRS Discussion Boards
Fuel pump
  • John C.
    • September 30, 2001
    • 130
    Fuel pump
    On my 59 283 fuel pump it seems that the bottom is always wet with gas not leaking just wet on the bottom gasket is this normal
  • Terry D.
    • May 31, 1987
    • 2696
    Re: Fuel pump
    No not normal, leaking somewhere, fire hazard.
    • Frank D.
      • December 27, 2007
      • 2703
      Re: Fuel pump
      No. Make sure the fuel lines are tight, then go around the bottom of the pump and carefully tighten the diaphragm perimeter screws, they are often loose...the same with the two bottom cover screws (but don't crazy with them). Beyond that you may well have a leak at the mounting gasket, or, the gasket behind the block plate that holds the push rod up...
      • John C.
        • 130
        Re: Fuel pump
        Thanks that's what I thought
        • Keith R.
          • August 31, 2001
          • 661
          Re: Fuel pump
          I agree with Frank. I use AV gas and noticed blue residue around the base of the fuel pump a week or so ago. I found that the diaphram screws around the perimeter were rather loose so I tightened them up, cleaned off the residue and haven't had a leak since.
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          2013 427 Convertible
          Shade tree mechanic and
          B-52 pilot extraordinaire
