'65 Power Brake Outlet Line(s) Clamp - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 409
    Trying to find the correct clamp for my '65s power brake outlet pipes. According to the AIMS (UPC: J50, Sheet 1, Item #1) it's GM part number 3113732. However, when I went to search for this part number all I could find is it being made from white plastic, copper and/or aluminum. And, when I look into the 6th Edition Technical Information & Judging Manual (ref: page 186, photo C 1-12) it shows it being a "thin natural steel C strap, which looks nothing like the different material straps . . . .
    Can anyone shed any light on where to find and buy the "thin natural C strap" that is shown in the judging manual?
    Appreciate any / all help . . . .thanks a bunch.
    Ray K (#43777)
  • Don H.
    Moderator
    • June 16, 2009
    • 2282
    Re: '65 Power Brake Outlet Line(s) Clamp
    Might this be the clip?
    1965-1967 Corvette Master Cylinder Line Clip at Zip - restoration components to rebuild your C2 & C3 Corvette's disc brake system & master cylinder. (GM Part 3666901)
    • David B.
      • March 1, 1980
      • 690
      Do not know if this will help you but 3113732 is a Harrison Radiator part number. If the AIM part is what you want I would look in that direction.
      • James W.
        • December 1, 1990
        • 2673
        As Don said ZIP has them, I bought mine from LIC.
        James
        • Ray K.
          • April 30, 2005
          • 409
          Thanks guys, I went to the ZIP and LIC websites and found it on both . . . .
          Also found it interesting that ZIP shows the clamp as part number: 3666901 and the '65 AIM shows it as part number 3113732.
          Makes you wonder if the wonder when the part number changed, or, was it incorrectly identified in the '65 AIM?
          Thanks again and stay healthy . . . .
