C2 Seat Belt Reinforcement Cable Source ? - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 951
    Does anyone know a source for these cables ? All the Corvette vendors seem to be out and list this as discontinued.
  • Tom E.
    • June 1, 2019
    • 448
    • Mark P.
      • May 13, 2008
      • 951
      Re: C2 Seat Belt Reinforcement Cable Source ?
      Thanks Tom. I appreciate it.
      • Jim D.
        • 2885
        I've stripped, replated and used heat shrink tubing on several sets with good results. Unfortunately your cable is damaged so replacement is in your future.
        • Joe R.
          • July 31, 1976
          • 4552
          These have resided on my shelf for some time. Don't know where they came from. Need some TLC.
          • Mark P.
            • May 13, 2008
            • 951
            Hi Jim - those look nice. I'll try to do the same. After plating did you push the cable all the way through one of the holes then slip the tubing on, shrink it then pull it back into position ?
            Mark
            • Mark P.
              • May 13, 2008
              • 951
              Thanks Jim and Joe. I restored the cables I got from Joe and am now good to go. My Caswell's plating set-up works OK but the parts are a little blotchy. I am fine with it though. The heat shrink tubing worked well. IMG_5293.jpg
              • Enzo C.
                • January 12, 2012
                • 536
                Is there a washer and than the nut or only the nut ?
                Enzo Colosimo
                Ncrs Ontario Chapter Chairman 🇨🇦
                ENZ-Z06/67
                • Mark P.
                  • May 13, 2008
                  • 951
                  Seat Belt Retainer.jpgHere is how they are attached for the outside retainers.
                  • Robert P.
                    • October 19, 2019
                    • 322
                    Hi, could you tell me what size heat shrink tubing you used and where to purchase
                    thank you very much
                    Bob Peckham
                    • Mark P.
                      • May 13, 2008
                      • 951
                      Hi Robert - I bought it off EBAY for about $4 shipped. I bought 2 ft so I got four 6" pieces.
                      Here is the title "3/8" ADHESIVE LINED HEAT SHRINK TUBING PREMIUM OEM GRADE - USA MADE BLACK - $/ft ".
                      Here is the description:
                      This is high quality commercial grade heat shrink tubing with adhesive lined and dual-walled polyolefin tubing, perfect for protecting the point of connection from the elements. The meltable sealant provides a barrier from corrosion and resistance. Ideal for marine and auto battery cables and wire termination points. Creates an OEM-like finish - extremely strong, flexible, and waterproof.
                      Comes in 6" pcs and is available in red, black, and clear. If you purchase a quantity of 1, you will receive two 6-inch pcs of tubing.
                        • 3 to 1 Heat Shrink Ratio
                        • 3/8" is the perfect size for waterproofing standard electrical connections (22-10 AWG)
                        • Continuous operating temperature range of -55C to 110c
                        • Advanced adhesive lining and sealant provides moisture-proof seal
                        • Flame retardant adhesive
                        • Flexible after shrink but remains extremely durable
                        • UL Listed and RoHS Compliant
                        • Specifications: AMS 3634
                        • Specifications: AMIL-I-23053/4 - CLASS 3
