283 ci engine - NCRS Discussion Boards
283 ci engine
    Infrequent User
    • December 15, 2019
    • 14
    283 ci engine
    Dear Friends,
    I'm Patrick from France and restoring my 1959 C1.
    I took off the 350ci and bought two weeks ago an old worn out 1958 283CI with good casting numbers (3737739) but wrong assembly stamping : F 918 D.
    It would be possible to restore it and I found a specialist for machining it: cilinder boring? change the cilinder liner?.
    Could you advice me a good technical book for rebuilding this engine .
    Thank you for your help.
    Best regards
    Patrick
  • Gary C.
    Administrator
    • October 1, 1982
    • 17768
    Re: 283 ci engine
    Patrick,
    You might want to contact Rob Musquetier in the Netherlands. You can find Rob listed in the Members pull down menu and send him an email.
    Rob knows a good engine rebuilder and could be very helpful to you since he owns a very nice 1959.
    Good luck and welcome to NCRS.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Dan A.
      • May 31, 1974
      • 1073
      Re: 283 ci engine
      Unless you have an very early '59 the 739 block casting would not be considered a good casting number for a 1959 model year Corvette if at all.
      • Ed S.
        • August 6, 2014
        • 1377
        Re: 283 ci engine
        Patrick, I am going to try to attach a PDF file - it is a technical reference published by GM, specifically for the 1959 Corvette - it is a great reference, I am also attaching a link to the document. You can find it on the GM Heritage Center website. Lots of good info - scroll down to page 24 of the document - that is where the details about the engine clearances and measurements are. Hope this helps. https://www.gmheritagecenter.com/doc...-Corvette.pdfp
        Ed
        • Gary C.
          Administrator
          • October 1, 1982
          • 17768
          Re: 283 ci engine
          Patrick,
          Another good contact is Tom Falconer in the UK. Tom's also listed in the Members tab pull down menu.
          Gary
          NCRS Texas Chapter
            • 43246
            Re: 283 ci engine
            Originally posted by Patrick Halbout (66592)
            Dear Friends,
            Best regards
            Patrick
            Patrick------
            A good reference for rebuilding small block Chevrolets is "How To Rebuild Small Block Chevrolets" by David Vizard. It's published by HP Books but I do not know if it's currently in print. It's a very practical tutorial on Gen I small block engine rebuilding. Of course, it's only in English. Even if it's out-of-print you could probably obtain a copy on eBay.
              Infrequent User
              • December 15, 2019
              • 14
              Re: 283 ci engine
              Gary,
              thank you for your message
                Infrequent User
                • December 15, 2019
                • 14
                Re: 283 ci engine
                Dan,
                Thank you for your note.
                The VIN number is J59S102308: if I don't make a mistake, the car was assembly in November 1958 so it's not to bad and better than a 1969 350ci?
                And it's very difficult to find a old 283ci in France.
                  Infrequent User
                  • December 15, 2019
                  • 14
                  Re: 283 ci engine
                  Ed,
                  Many thanks for these links.I still have a lot of work!!!
                    Infrequent User
                    • December 15, 2019
                    • 14
                    Re: 283 ci engine
                    Joe,
                    Thank you for this reference: I order it on Amazon without difficulty!
                    • Bert L.
                      • April 30, 1977
                      • 427
                      Re: 283 ci engine
                      Allo Patrick,....Best of luck with your restoration project, please continue to keep us updated as you progress...
                      Your photos are excellent!
                        Infrequent User
                        • December 15, 2019
                        • 14
                        Re: 283 ci engine
                        Dear Bert,
                        I perform this restoration at home: thank you for your interest.
                        I think I'd still have many questions even the 1958-1960 5th edition CTIMJ Guide is very useful!
