Door repair - NCRS Discussion Boards
Door repair
  • Kenneth F.
    • September 30, 1988
    • 285
    Door repair
    I am working on the door on my 1962. The large inspection cover screws have stripped what were the threads in the fiberglass. I thought I would use J-Nuts to repair, but could not find a part number online. Perhaps someone would have a better idea than J-Nuts.
    Thank you,
    Ken
  • Richard G.
    • July 31, 1984
    • 1718
    Re: Door repair
    A bunch of methods to deal with this issue.
    I'll only mention one.
    The Thread setter tool. Typically used for inserting threaded inserts into sheet-metal.
    They can be used on fiberglass and work quite well. Sometime called Poly-nuts.
    Typically work with machine screws so you would have to change out the screws.
    • Dan P.
      • December 1, 1990
      • 683
      Re: Door repair
      You can find the jnuts on Ebay.The door panel screw holes will also strip out.. I beveled the hole out and the used fast setting JB weld and re-drilled the holes .
      • Kenneth F.
        • 285
        Re: Door repair
        Thank you Richard and Dan.
        Ken
        • Gary C.
          Administrator
          • October 1, 1982
          • 17940
          Re: Door repair
          Ken,
          You can also use the small white plastic wall anchors, like for hanging small stuff on walls.
          JB Weld works best.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Pat H.
            • December 1, 1996
            • 421
            Re: Door repair
            I (my Body person)used fibre glass cloth with resin. A small piece on each side of the stripped out holes. I re-drilled the holes when I put the car back together. Just be careful not to over tighten.
            • Kenneth F.
              • 285
              Re: Door repair
              Thank you Gary and Pat. You have some good ideas I can work with.
              Ken
              • Frank D.
                • December 27, 2007
                • 2703
                Re: Door repair
                That's the way to do it IMO; I've seen everything from wall anchors to a flat metal plate you rivet to the door on one end and put a threaded hole in the other end over the damaged are -- for door repairs. You shouldn't be in the inspection area that often; a good OEM-style glass repair is what I do.
                • Tony R.
                  • April 19, 2017
                  • 201
                  • Kenneth F.
                    • 285
                    Re: Door repair
                    I used the slower drying J-B Weld. When I drilled for the screws, I was surprised how hard the material is. I was able to tighten the screws quite a bit.
                    Thanks to all for the great suggestions.
                    Ken
                    • Paul Y.
                      • September 30, 1982
                      • 570
                      Re: Door repair
                      Thank you,
                      Ken
                      Ken, I have used the flat metal retainer pieces and bonded them to the inside of the door. They are sized by the size of screw and large enough that they woudnt pull through for a nice secure strong tight fit. Paul
                      It's a good life!
