How to remove 69 windshield washer push button - NCRS Discussion Boards
+ More Options
Posts
  • Richard R.
    • January 5, 2010
    • 270
    I'm working on restoring the dash components on my 69 L46 convertible. The wiper push/slide button/switch is attached to the bezel with a shaft through the bezel and a plastic button pressed on the switch shaft. I want to remove the switch so I can paint it and can't get the button off the switch assembly. Anyone have a trick for how to do this without ruining the plastic button?
    Rich
  • Gary B.
    • July 31, 1979
    • 926
    Re: How to remove 69 windshield washer push button
    Pull. If you have to, use a flat blade screw driver to wedge it off. Be careful, the screwdriver blade will gouge the plastic. Just a good pull usually gets them off.
    Gary B
    • Richard R.
      • January 5, 2010
      • 270
      got it off. I didn't want to damage the switch by putting too much pressure on it. But with Gary's encouragement, I held onto the bar that holds the button to the switch with a pair plyers, then applied a bit of pressure on the button with a screwdriver, between the bezel and the button. Came right off.
      Thanks Gary!
