C2 Hardtop Side Retainer Removal - How To - NCRS Discussion Boards
  • Brian M.
    • November 1, 1994
    • 128
    Esteemed colleagues,
    How does one remove the hardtop side retainer from the rear deck without damaging the fiberglass? I cannot find a way to grasp the bolt.
    I have searched the TDB without success for guidance.
    I am sure there is something simple and would rather not drill them out.
    I suppose I can always leave in place and paint around them.
    Any help would be sincerely appreciated.
    Thanks in advance
    Brian McIntyre
  • Donald O.
    • May 31, 1990
    • 1591
    Re: C2 Hardtop Side Retainer Removal - How To
    I used a needle nose vise grips on the outer "screw" and a regular wrench on the inner nut. Yes, I had to replace the outer "screw".
    Don
    • Gary J.
      • April 1, 1980
      • 1244
      Brian, if you have the rest of the car stripped as the deck lid you have it pretty clean
      • Alan D.
        • January 1, 2005
        • 2046
        Run a screw into outside, double nut, hold and remove back nut.
        • Mike M.
          • May 31, 1974
          • 8399
          Alan is no dummy. his method won't scar the "screw". mike
          • Brian M.
            • November 1, 1994
            • 128
            Alan,
            Thanks for the suggestion. That was my first thought.
            Sheared the screw.
            Will try a higher grade screw before resorting to another means.
            Brian McIntyre
            • Brian M.
              • November 1, 1994
              • 128
              Thanks.
              See the Redline Times article on stripping the 13 layers of paint and Imron.
              Fortunately I am retired now.
              Brian McIntyre
              • Dino L.
                • February 1, 1996
                • 694
                I used Alan’s approach, however the nut was rusted so I placed a bolt inside with a small weld then backed the nut off , then ground the weld off and polished the surface and reused it. No sign of process.
                Dino Lanno
                • Brian M.
                  • November 1, 1994
                  • 128
                  Dino,
                  Thanks.
                  It might come to that.
                  Brian McIntyre
                  • Dino L.
                    • February 1, 1996
                    • 694
                    Be careful with the weld, the heat burns the fiberglass, heat sink it before welding it!
                    Dino Lanno
                    • Brian M.
                      • November 1, 1994
                      • 128
                      Oh yes I will if that is where I end up.
                      I bought some grade 8 bolts and will give it another twist first.
                      Thanks!
                      Brian McIntyre
                      • William B.
                        • April 30, 1975
                        • 942
                        Try this penetrating oil, John Degregory suggested it to me, works were others do not, look on ebay or most of the HVAC parts stores handle it
                        Kano Aero kroil Penetrating Oil,
                        • Dick W.
                          • 10483
                          Doc Q is right, safest way to remove the nut. No flaming Blue Point wrenched required
                          Dick Whittington
                          • Brian M.
                            • November 1, 1994
                            • 128
                            FWIW, I ended up pilot drilling one of the flats on the nut and then used a small burr to through cut the nut. I can even reuse the bolt part after I chase the threads.
                            Another way to do it if you do not have a welder. It took about 20 minutes per nut.
                            Thanks for the ideas.
                            Brian McIntyre
                            • George C.
                              • November 1, 2001
                              • 568
                              Excellent job, glad to hear you got it done without having to resort to the welder.
