Open Differential with a 350hp engine? - NCRS Discussion Boards
  • Dan A.
    • May 31, 1974
    • 1073
    Interesting rear gear in that '66 Jack.
  • Jack M.
    • March 1, 1991
    • 1196
    Re: 66 Protect-O-Plate paint code; Mossport Green
    Dan- I believe it was the standard axle ratio with that engine... when ordered with the M21.
    (NOTE: This is not my car, but feel free to email me if you want more particulars.)
    • Dan A.
      • May 31, 1974
      • 1073
      Yes Jack the '65 finger tip facts bares that out. Same 3:70 gear was the factory standard when an optional gear wasn't ordered for the L76 and L84 too. But it does not appear to stipulate posi. One might think the L78 would follow suite with the 3:70 as the factory std gear. But the Finger Tip Facts Revision page lists the 3:36 as factory std. But it does stipulate posi.
      The car you cite appears to have a 3:70 open dif with the AS code. The fact that it has an open dif with a 350hp engine is what I find interesting. Most open dif's I've seen were in base engine cars. Also when it can be shown that the original ordering buyer had to juggle options to fit a tight budget.
      • Jack M.
        • March 1, 1991
        • 1196
        Dan- Just seeing an email from you... I'll continue offline (instead of potentially hijacking Mike's thread).
        • Leif A.
          • August 31, 1997
          • 3654
          Apologies to the OP as we've swerved a bit off subject, but to your point Dan a picture of my diff in my '67 L79, M21 coupe. Built June 14. 3:70 open diffs were standard ratio with the L79 and M21 (in 1967).
          Leif
          • Dan A.
            • May 31, 1974
            • 1073
            Your absolutely right once again Jack. My apologies to the OP for Hijacking his thread. Also my bad I was referencing a '65 info for a '66 car.
            Very good photo Leif, thanks. '67 Factory std. 3:70 w/close ratio, 3:36 w/wide ratio.
            • Leif A.
              • August 31, 1997
              • 3654
              Dan,
              Correct. I ammended my earlier post.
              Leif
              • Jack M.
                • March 1, 1991
                • 1196
                C2 Power Teams
                These charts don't address all the factory updates, but it should give you a decent representation of C2 Power Teams:
