454 engine build - NCRS Discussion Boards
454 engine build
  • Tom B.
    • March 1, 2002
    • 140
    454 engine build
    Just tore apart this 454 I have had for 15 yrs . Was supposedly re done when I got the car. Its .030 over TRW L2465 forged pistons has 69 063 heads .Pulled the cam has numbers VA 5104 280 S and CO but cant read the 3rd character? Edelbrock Preformer 2 intake, No carb I havent messed with any big block builds since 73 any advice would be greatly appreciated for the build.Any ideas on carb and ignition? Maybe Duke has some thoughts?
    • 43279
    Re: 454 engine build
    Tom------
    A very lot depends upon what you intend to do with the engine and what you want out of it. For example, the Performer 2 intake manifold is not a bad manifold (assuming it's an oval port version to match your oval port heads) but it will not fit under a 68+ Corvette big block hood (except L-88 hood).
    • Tom B.
      • March 1, 2002
      • 140
      Joe..... just want kind of a hot day 2 street car. Going to run this motor in my 69 Camaro. The last time I messed with big blocks was 70-72 back then it was a 396 with 840 heads and a ZL1 Cam and 10.5 to 1 pistons and an 850 Holley not sure what carb or cam to run in this motor for a street car.
        • 15706
        I certainly wouldn't use a racing cam. Does it have a forged or cast crank? How about the rods? Bottom end strength and durability on a long stroke engine are going to be a big factor in determining "design speed" - the maximum allowable RPM.
        As with any engine I always recommend massaging the heads, and then for a road engine selecting a cam that yields at least 80 percent peak torque at 2000 if a manual trans and 90 percent if an automatic.
        I rarely establish a top end power objective unless it's a Bonneville car, where top end power is all that counts. On a road racing engine the usual objective is maximizing average power in the top 30 percent of the rev range and on a road engine maximize the average from 1500/2000 to design speed while making the torque bogey mentioned above.
        • Dick W.
          • 10483
          Piston specs: Comp Ratio: 11.31:1 w/100.9cc Heads, 9.61:1 w/119cc Heads I believe with the heads you have, unless they have been decked, the compression ration of 9.0 (most likely closer to 9.0-1 would work fine. I am using the same pistons in a cast iron set of open chamber heads with good drive-ability.
          Dick Whittington
          • Dick W.
            • 10483
            Dick Whittington
            • Tom B.
              • March 1, 2002
              • 140
              Duke....have not pulled the pan to ck the bottom end yet. Any ideas on carb size? car will have a M20 trans and anywhere from a 308 to 355 axle gear
              • Dick W.
                • 10483
                3.08 gear with that cam could be a little aggravating in traffic. 3.36 or 3.54 would be better. For simplicity I would go with a properly tweaked Quadrajet
                Dick Whittington
                • Tom B.
                  • March 1, 2002
                  • 140
                  Dick....any idea what that cam is and specs on it?
                  • Dick W.
                    • 10483
                    I started researching the numbers and got busy, I will try tonight, I am up to my wazoo in alligators right now.
                    Dick Whittington
                    • Patrick B.
                      • August 31, 1985
                      • 2012
                      • Tom B.
                        • March 1, 2002
                        • 140
                        Patrick....the 69 063 head is 101 cc
                        • Patrick B.
                          • August 31, 1985
                          • 2012
                          Unless you want a 11.3 compression ratio, you can machine the piston domes down a bit and cut the combustion chambers to unshroud the valves to get a more reasonable compression ratio.
                          • Dick W.
                            • 10483
                            Oops! I had the head volume mixed up in my post.
                            Dick Whittington
                              • 15706
                              Carb size depends on design speed, but something in the 700-800 range should be okay. Beware of aftermarket cams. Most have too much overlap for a given duration, which kills low end torque. The 390/400 HP cam would be a real toque monster with good top end power and up to 6000 useable revs with well massaged heads, and the L-72/71 cam would work well - a bit less low end torque with more top end power.
                              There are HUNDREDS of cams out there to choose from, and it's real easy to make a mistake especially if you don't have a good handle on desired broad range performance characteristics and just pick some peak HP number out of the air, which is what most guys seem to do.
                              A torquey 454 will work very well with a WR trans and 3.08 axle.
