Flush radiator - NCRS Discussion Boards
Flush radiator
  • John C.
    • September 30, 2001
    • 130
    Flush radiator
    Can someone please take me through the proper steps on flushing out the radiator including the refill with antifreeze
    Thank you John
  • Pat H.
    • December 1, 1996
    • 421
    Re: Flush radiator
    I took my 59 Rad to a rad shop, (may be hard to find these days) and had it flushed and pressure check priot to installation. When filling make sure the heater is on so that the coolant gets into it. Once filled, drive it around and then check again if more is coolant is required. If you over fill it, it will probably come out the overflow
