70 3 Piece Distributor Shield Phillips Screws - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Looking for details on the phillips head screws that attached the two halves together on the 3 piece distributor shield.
    How long, head diameter, etc.
    A GM part number would be great.
    Thank you ,
    Bill
    • 43222
    Re: 70 3 Piece Distributor Shield Phillips Screws
    Thank you ,
    Bill
    Bill-------
    The GM Part number was 163162. However, it was never available in SERVICE.
    I have some of these on my original shielding but I can't get at it right now. As I recollect, the screws were self-tapping, pan head phillips. I believe they were size 6 but I'm not sure. They were short-----maybe 1/2" to 5/8" and were zinc plated.
    • Bill L.
      • February 1, 2004
      • 1403
      Bill-------
      Thank you Joe.
      Kind Regards,
      Bill
      • Jim R.
        • August 31, 2002
        • 95
        Be careful a longer screw will prevent the breaker plate from moving with vacuum advance
        • Mike E.
          • February 28, 1975
          • 5139
          Jim,
          I am not sure I understand your post. How/where do the shielding screws interfere with the breaker plate?
          Mike
          • Jim R.
            • August 31, 2002
            • 95
            If you use a screw that is longer than the original length, the longer screw will hit the distributor housing beneath the plate and prevent the plate from moving. I had this happen.
              • 43222
              Jim------
              Yes, you're correct regarding the internal 2 piece RF shield used to shield the points and condenser for 1970-74 Corvettes. However, I believe the original question involved the screws on the 3 piece shield on radio-equipped Corvettes which surrounded the distributor for RF shielding. That shield was used for L1969-E1970.
              • Jim R.
                • August 31, 2002
                • 95
                Correct wrong shield my bad.
                • David L.
                  • July 31, 1980
                  • 3310
                  I sold all my 70-74 RF shields but I found this photo on the web.
                  Dave
