'72 LS-5 Idler pulley - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    The idler pulley on my LS5 w/ a/c is making some noise. Is the bearing assembly available or am I looking at buying the entire pulley assembly?
  • Ray K.
    • July 31, 1985
    • 375
    Re: '72 LS-5 Idler pulley
    Tom,
    Chevrolet serviced the bearing as an individual component. Part #908050 or #908076. Check the Corvette vendors to see if they have it available. Small block or big block with an idler pulley used the same bearing.
    Ray
      • 43277
      Originally posted by Ray Kimminau (8917)
      Tom,
      Ray
      Ray and Tom------
      The idler bearing assembly was last available under the GM #908076 part number but it's been discontinued now for several years. Replacements are available in the aftermarket, though. I think the best ones are manufactured by Koyo. Japanese-manufactured bearings are the best on the planet.
      • Dick W.
        • 10483
        There is an OEM on fleabay right now Not my part and I do not know the seller. https://www.ebay.com/itm/OEM-GM-9080...YAAOSw3Dtd9oPU
        Dick Whittington
