1963 Door Skin Question - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    I came across an NOS 63 door skin. It is not gray but a yellowish white. I had a few folks agree that it is an NOS piece. Here is the question.
    On the very early 63 door skins did they come out of the mold with or without the holes for the handle, lock and mirror. This skin has no holes for those three items.
    I've seen NOS gray skins with the holes.
    Puzzled minds want to know.
  • Donald L.
    • November 1, 1981
    • 141
    • Donald L.
      • November 1, 1981
      • 141
      Re: 1963 Door Skin Question
      One other thing 63 door skins can be used on coupe or convertible because of the seam on the cp door.
      • Harry S.
        • July 31, 2002
        • 5344
        Yes, I agree
        • Harry S.
          • July 31, 2002
          • 5344
          Don, I sent you a PM.
            • 43279
            Originally posted by Harry Sadlock (38513)
            Yes, I agree
            Harry------
            The reason for the different configurations of the outer door panel is probably because of the several different part numbers over the years. Here's the sordid detail regarding the 1963 OUTER door panels:
            convertible:
            LH---GM #3797013>1/64> GM #3839809>3/65>GM #3854677>10/67> GM #3903557>discontinued 6/84
            RH---GM #3797014>3/65> GM #3854678>7/67> GM #3903558> discontinued 10/79
            coupe:
            LH, UPPER---GM #3797042>3/65> GM #3840779> discontinued 7/69
            LH, LOWER---GM #3797045>3/64> GM #3839811>discontinued 5/72
            RH, UPPER---GM #3797048>3/65> GM #3840780>discontinued 7/69
            RH, LOWER---GM #3797046>discontinued 3/71
