1963 Drive Shaft Stencil - NCRS Discussion Boards
  • Greg B.
    Infrequent User
    • July 31, 1997
    • 20
    The judging manual for the '63 indicates that the drive shaft should have the P/N stenciled on it. I'm trying to determine the P/N, font size, and print color. Can anyone advise or provide the name of a stencil supplier? Regards, Greg Barr
  • Richard G.
    • July 31, 1984
    • 1718
    Re: 1963 Drive Shaft Stencil
    I do not know if this will help but here it is anyway.
    I failed to find a stencil so a friend of mine, that is a graphic artist, helped me with this one.
    I guessed at the size and printed it and cut it out using an exact-o knife.
    Best of luck
    Rick
    • Harry S.
      • July 31, 2002
      • 5330
      I've been scratching my head and I do not recall seeing any stenciling on 63 to 67 drive shafts. I do know there are painted rings on the shaft.
      Peek at -----> https://www.forums.ncrs.org/showthre...ght=driveshaft
      • Don L.
        • August 31, 2005
        • 1005
        No idea if they have exactly what you need for your car or not but I have bought and used d/shaft stencils from Quanta. I just checked their site and one can be bought for $12.
        Hope this helps.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Greg B.
          Infrequent User
          • July 31, 1997
          • 20
          Thanks Richard
          • Greg B.
            Infrequent User
            • July 31, 1997
            • 20
            Don,
            Thanks for your response. I called Quanta and they said they didn't make one. I'll check their website.
            • Greg B.
              Infrequent User
              • July 31, 1997
              • 20
              Hi Don,
              I just checked the Quanta website. The drive shaft stencil they offer covers '56 to '62. I'll call them Monday and see what I can find out. Thanks, Greg
              • Ray K.
                • July 31, 1985
                • 375
                Don,
                Can not say with 100% certain on '63 driveshaft, but my 1965 definitely did not have a stenciled part number. Whereas, as noted above the 1956 - 62 Corvettes driveshafts were stenciled with a part number.
                Ray
                • Don L.
                  • August 31, 2005
                  • 1005
                  If, as Quanta reports, there was a stencil for '56 through '62 but not for '63, I find it interesting how sometime later, GM went back to stencils on driveshafts. I'm not a C2 guy, so I don't have any Judging Guides for Midyear cars. I do, however, have the 5th Edition of '70-'72 and Fig 8.35 (Chassis section) details driveshaft part number 3921675 on the shaft in yellow stencil. Characters shown in Fig 8.35 are very similar to this detailed above in this thread. Seems some '63 benchmark examples would be helpful as reference.
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Harry S.
                    • July 31, 2002
                    • 5330
                    Here is what I found:
                    53 - 55 3707878
                    55 - 62 3712377
                    63 - 67 orange and green paint rings 4spd & auto.
                    68 - 70 3957056 auto 3921675
                    71 - 72 3921675
                    • Gary B.
                      • July 31, 1979
                      • 926
                      Harry,
                      Yah have to remember, 68's were a pile of left over 67 parts. The drive shafts were paint-striped in 68 also, the stencil's started in 69. Page 239 of the 5th Edition 68-69 TIM&JG.
                      Gary Bosselman
                      • Alan D.
                        • January 1, 2005
                        • 2046
                        I do not recall anyone mentioning any part numbers stencil on C2 Propeller Shaft, aka driveshafts. The print for driveshaft, 3868727, release date of 6/64 mentions the painted rings - no requirement for part number. Besides the early driveshafts got hit with blackout so one would not see those part numbers.
                        Attached some great info from the 1990 time frame.
                        • Frederick H.
                          • August 31, 1983
                          • 458
                          Am in the process of balancing and refinishing my '63 driveshaft and also saw the mention of a stenciled part # on the driveshaft, even in my '94 Judging Manual. However, multiple photos in Noland Adams book show the drive shaft fully covered in blackout, so not sure how the judging will continue on this. I guess to play it safe - you could do the stencil and the green and orange stripe that Harry mentions and then if you get dinged, do the blackout.
                          • David B.
                            • March 1, 1980
                            • 689
                            5-14-64 Assembly - Propeller shaft and universal joint Drawing # 3868727
                            "Paint No. 248-0679 yellow or equivalent
                            opt. 248 - 59863 light green or equivalent Marking to be at rear of the tube next to nearest exposed trunion and as close as possible to light side at rear of assembly when balanced"
                            '63 Corvette early #3843002 same
