Block Casting Date Question - NCRS Discussion Boards
  • Ralph P.
    • February 1, 1990
    • 253
    This ia a 67 3904351 block from a mid-January car. Pad and and transmission dates line up within 30 days prior. The block cast date is the question.... should be December 66. But,the "L' character appears reversed. Is this somethins seen since it was a manual process? Are there other known blocks in with this error?
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: Block Casting Date Question
    Looks like F176 possibly which would be WAY early. With GM anything is possible Upside L possible Your guess is as good as anyone's
    • Keith B.
      • September 15, 2014
      • 1592
      you need to hunt down other blocks cast on the same day. start with finding cars built the same day as yours and finding assembly stamps that are close. be like finding a needle in a hay stack though
      • Ralph P.
        • February 1, 1990
        • 253
        Yes, hoping someone will pop up here with similar date !
        • Keith B.
          • 1592
          Have you gotten in contact with Al Greening he has thousands of stamp pads and casting dates on file.
          • Patrick B.
            • August 31, 1985
            • 2003
            351 blocks were definitely being cast on June 17, 1966, and this appears to be one. What is the assembly date? Sometimes there were gaps of 6 months between between casting and assembly of big blocks. Post a picture of the pad.
            • Ralph P.
              • February 1, 1990
              • 253
              Posting for a buddy... Assembly date was 1/04/67.... Will see if I can get pad picture. Thanks
              • Mark L.
                • 561
                My 1967 427 car had an engine ass'y date of 1/4/67. The cast date was J206.
                • Patrick B.
                  • August 31, 1985
                  • 2003
                  • Ralph P.
                    • February 1, 1990
                    • 253
                    Good idea, I'll try to get a photo of his pad ! Still need to determine if an L or other character? Up close, really looks like an inverted L....
                    • Gary J.
                      • April 1, 1980
                      • 1245
                      • Mark L.
                        • 561
                        Pat, here it is. One of the mechanical judges was Al Grenning when it got the Duntov Award.
                        • Patrick B.
                          • August 31, 1985
                          • 2003
                          It looks real good. Hopefully, Ralph can post a picture.
                          • Ralph P.
                            • February 1, 1990
                            • 253
                            Great looking pad.... I hope to have a couple to compare today. I do have a couple more of the casting date to post. Do we for sure know 351's were cast in mid June? It sure as heck looks like an inverted "L".
                            • Ralph P.
                              • February 1, 1990
                              • 253
                              Here's couple more of the block cast date....
