Adhesive wheel balancing weights - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    What is the least damaging way to a aluminum wheel to remove the adhesive attached wheel weights? The weights in question are on the inner side of TTD wheels and not visible until I rotate the tires/wheels. Getting ready for a new set of Diamondback redlines.
    Don
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Adhesive wheel balancing weights
    Mineral spirits will usually remove the adhesive without damaging anything. Lighter fluid works also.
    • Warren M.
      Infrequent User
      • March 28, 2007
      • 6
      Prep- sol , grease & wax removal, bug & tar remover . All work well .
      • Mark S.
        • July 31, 1983
        • 664
        3M adhesive cleaner
        • James W.
          • December 1, 1990
          • 2671
          I second Mark's response. I also use the 3M Weather Strip Adhesive Cleaner to remove the remaining glue from the knock-off wheels.
          James
          Originally posted by Mark Swanson (6796)
          3M adhesive cleaner
          • Paul D.
            • September 30, 1996
            • 491
            To remove the weights, I use a heat gun (hair dryer would work) and a PLASTIC scraper or PLASTIC razor blade. This will get most out of the way, then use one of the products suggested above to remove the adhesive residue. Chip.
              • 15706
              Right... before you remove the residual adhesive you have to scrape off the weight. Harbor Freight sets a set of four plastic scrappers, 1.5 to 5" wide for a couple of bucks. They come in real handy, and the heat gun will make it even easier and virtually impossible to mar the wheel or paint.
              • Donald O.
                • May 31, 1990
                • 1593
                Re: Adhesive wheel balancing weights - DONE
                Only took 3 hours to do the four wheels.
                I used plastic scrapers then acetone, WD40, lacquer thinner, paint thinner, and naptha. I didn't use any MEK, Xylene, ot Toluene. Finished with a final cleaning with Awesome and then some spray detailer.
                Now to get the new red stripes.
                Thanks for all the ideas and tips.
                Don
                • Paul D.
                  • 491
                  Don, be aware that depending on what kind of spray detailer you used, you may have left a surface too slick for the weight's adhesive to work properly. I would wipe off with the acetone (or any wax/degreaser) before having balanced. You could always go back and reapply after weights are installed. Chip.
                  • Donald O.
                    • May 31, 1990
                    • 1593
                    Great tip!
