Odd '57 bellhousing? - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    The current '56 - '57 Judging Guide says the clutch fork pivot ball enters a #3733365 bellhousing casting from the rear (transmission) side. The June, 1957 bellhousing in the photos I've attached has a pivot ball that is mounted from the front. Is the Judging manual wrong, or is this particular casting feature uncommon?
  • Jim L.
    • September 30, 1979
    • 1816
    Re: Odd '57 bellhousing?
    That's a bell housing for a '57 2bbl 265 passenger car application, Jerry.
    In '57 (and maybe '56, too, not sure) all base V8/manual transmission passenger cars used that bell housing. All optional PowerPak V8s used the bell housing (same casting) with the stud screwed in from the transmission side.
    • G B.
      • December 1, 1974
      • 1407
      Thanks, Jim. I didn't know that. Perhaps I don't get out enough.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Jerry,
        Photo of screw in clutch stud.
        You're not by yourself. Plenty of us have done the same thing.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
