283 flywheel shim - NCRS Discussion Boards
283 flywheel shim
  • Stanley S.
    • December 14, 2007
    • 57
    Re: 283 flywheel shim
    Bill,
    I laid my flywheel with the side facing the clutch plate laying on a piece of window glass and then measured from the glass through the bolt holes to the surface that bolts to the crank flange and got .953". So it appears as if the .050" shim is the correct shim. It is true that my earlier measurement was total flywheel thickness.
    My crank flange has a hole drilled for an index pin but no pin is installed. I don't think it is the original crank however.
    Stan
      • 43279
      Originally posted by Stanley Schield (48300)
      Bill,
      Stan
      Stan------
      Is your crankshaft flange completely round or is it counter-weighted?
      • Stanley S.
        • December 14, 2007
        • 57
        #18
        Joe
        It is completely round. No sign of any counterweight.
        Stan
          • 43279
          #19
          Joe
          Stan
          Stan------
          Then I would opine that it originally had the indexing dowel pin.
