67 BBC Oil Plug and Fuel Pump Rod Plug - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 397
    Hi:
    Is the Fuel Pump Rod Plug (the plug under the fuel pump) and the large Center position Plug over the Oil Filter housing mounted before the engine is painted? I was under the impression that the oil pressure line and the adapters in the left most hole were installed after the engine drop, but am wondering about the other two previously mentioned plugs. Thanks for any responses.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
