1963 rear axle and code - NCRS Discussion Boards
  • Raymond R.
    • June 30, 1988
    • 115
    For a 1963 SW coupe, 327 ci, 250 hp, 4 speed with positraction; what rear axle ratio and code would you expect? Would it be CB 3:36.1 or something else? Where would you find the code on the axle? Thanks.
  • Harry S.
    • July 31, 2002
    • 5342
    Re: 1963 rear axle and code
    A 3:36 is probably the most reasonable but it could have been anything that you could order with the 250 HP engine. There is no code on the axle. It is stamped into the bottom of the pumpkin. There was also a tag on the rear installed to help identify the gears at factory build time. You may or may not have that. Check past threads for diagrams of the tags.
    • Raymond R.
      • June 30, 1988
      • 115
      Thanks for helping me out again, Harry. You have always been there with answers to my questions. Much appreciated.
