C 4 Tail light, brake light, back up and side markers light failure 1993 Convertible - NCRS Discussion Boards
    • October 17, 2013
    • 69
    Members,
    I lost all rear light the other night, Brakes, tail, side markers and rear. I checked the ground on the drivers side and it seems good. Are there other ground locations? All fuses are good all front and front side marker and turn lights are functional. 40th Anniversary Convertible.
  • Chris G.
    • October 22, 2006
    • 94
    Re: C 4 Tail light, brake light, back up and side markers light failure 1993 Converti
    There is a harness connector in the right rear area behind the carpet, it is VERY susceptible to water damage. Pull your trim back and inspect this harness connection. My bet is the entire harness connector will be corroded green. It is a good starting point without further information.
      • October 17, 2013
      • 69
      Thanks Chris I'll give it a look later today.
      John
