ground straps - NCRS Discussion Boards
ground straps
  • Mel S.
    • August 31, 1992
    • 264
    ground straps
    I have a 66 convt. 4-speed 350 with factory side pipes. i am doing a body off restoration. i looked in the AIM for all of the grounding strap(s) locations but did not see it/them. Can anyone help me? I know of the one on the gas pedal linkage and the one on the antenna back by the D/S rear tire.
    Mel
  • David L.
    • July 31, 1980
    • 3310
    Re: ground straps
    Mel,
    UPC U69, Sheet A4 in the 1966 Corvette AIM.
    Dave
    • Keith B.
      • September 15, 2014
      • 1604
      Re: ground straps
      section RPO U69 has the page with the ground strap location
      • Jim D.
        • 2885
        Re: ground straps
        Look in the A.I.M. under the U-69 option. That will show all the locations. Obviously,with side exhaust you don't use the 2 on the exhaust clamps at the trans. crossmember.
        • Mel S.
          • August 31, 1992
          • 264
          Re: ground straps
          Thanks to all
          Mel
