1966 Clock - NCRS Discussion Boards
1966 Clock
  • Timothy B.
    • August 4, 2008
    • 44
    1966 Clock
    I have started to take apart this 1966 clock and have not been able to remove the chrome knob.
    I believe that it unscrews from the shaft, clock or counter clock wise? Is that correct?
    Any suggestion would be appreciated.
    I have used a little PB Blaster.
  • Steven B.
    • April 11, 2012
    • 233
    Re: 1966 Clock
    They are right hand threads. I have had luck with using the flat part of small vice grips to hold the shaft. If by chance anything gets a scar, replacement parts are readily available.
    • Timothy B.
      • August 4, 2008
      • 44
      Re: 1966 Clock
      Thank you.
