need photo of original c-2 heater motor and heater box LABELS - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7185
    Re: need photo of original c-2 heater motor and heater box LABELS
    Is that a '63?
    • Harry S.
      • July 31, 2002
      • 5349
      Is that a '63?
      It shouldn't be. 63's were covered with goop.
        • May 31, 1974
        • 8411
        Danny: thanks. that's what I was in search of. what year c-2 is it off of? can you make out what's printed on the label? this label is unlike the labels that were affixed to the backside of the heater boxes as these are larger than those inside the car. also, I suspect the heater motor, being exposed to the elements ,would help explain the scarcity of labels on heater motors and the relatively mild environment inside the cockpit would explain why almost all c-2 heater boxes I've restored have a preserved label on the backside of the heater box. thanks again, mike
        • Danny P.
          • June 30, 2002
          • 344
          .Mike itโ€™s 1966 looks like the # 31414
          • Ronald L.
            • October 18, 2009
            • 3248
            Mike - Just like the wrong size BB fan shroud stickers - that were UNDER the paint, not OVER ever!
            Did you get the dimensions on these inspection stickers?
              • May 31, 1974
              • 8411
              haven't received dimensions. mike
              • James W.
                • December 1, 1990
                • 2681
                Pictures from my unrestored '65 with a/c, sorry they are blurry.
                James
                • Daniel E.
                  • April 30, 2005
                  • 145
                    • May 31, 1974
                    • 8411
                    #24
                    thanks jim. apparently, the label that was fixed to the heater box(inside the car) was randomly attached. most i've seen were on the face of the box that faced the firewall and on the portion not far from the defroster ductwork. guess it all depends on the individual who attached the label. mike
                    • Stephen L.
                      • May 31, 1984
                      • 3163
                      #25
                      This is a photo of a 67 heater blower motor tag. (No A/C) Tag dimensions: 1/2"x 3/4". Early April build date for the car.
                      Last edited by Stephen L.; January 24, 2020, 05:22 PM. Reason: Build date. corrected dimensions
                        • May 31, 1974
                        • 8411
                        #26
                        thanks Steve. I suspected they were rectangular as opposed to the heater box labels inside the car. mike
                        • Daniel E.
                          • April 30, 2005
                          • 145
                          #27
                          Mike,
                          I agree with the dimensions Steve provided earlier. Also, the inside heater box labels are the same dimensions as the outer box labels. I measured labels from the inside box and outside box of a known original June 67 car.
                          Daniel
