59 shift linkage and levers - NCRS Discussion Boards
  • Ronald C.
    • March 1, 2002
    • 77
    I have my t-10 (1959) rebuilt and back in the chassis along with the correct shifter and new shift linkage and levers (correct style). and have adjusted the gates to near perfect, actually machined a piece of aluminum to align a perfect neutral. However the 1-2 shift rod only threads into the shift lever about 2-3 threads. and when shifting will actually pop out. I have tried to replace the levers and linkage with a set from corvette central but still the same issue. I have verified:
    - 1-2. 3-4 and reverse shift linkage are in the correct position
    - Shift levers are about vertical when in neutral
    anyone have a picture of a correct fully assembled levers and linkage on a t-10, the correct dimension for each shift linkage from the shifter eye to the end of the threaded rod for 1-2 and 3-4?
  • David B.
    • March 1, 1980
    • 691
    Re: 59 shift linkage and levers
    If you have a P & A catalog 62 or 63 there is a good illustration of 58-63 4 spd. trans & linkage. Grp.4.035 lists 1st & 2nd rod #3744070 as
    10 15/16" long and 3rd & 4th #3744071 as 14 9/16" long. The clevis is in Grp.4.037. Check your length.
      • 6960
      Dave can you manually put it in 1st and 2nd with the rod unhooked. Was the trans.Poping out when in first when you start to move?
      • Ronald C.
        • March 1, 2002
        • 77
        thank you for the rod lengths.. mine match. do you have the length of the clevis? i still cant get more than 1.5-2 turns of engagement.
