Need vacuum diagram for 435hp - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    Can anyone tell me where I can find good vacuum diagrams for the AIR system, and routing of the PCV hoses for my 69 435hp?
    I also need to know if the vacuum port behind the rear carburetor is used, and if so what fitting goes in there, and what connects to it? Paragon lists many fittings but none for a 69 435 without PB's and using a 4 speed. Thanks, Mark
    • 15679
    Re: Need vacuum diagram for 435hp
    The '67 CSM and '67 AIM should have what you need in both the base and option sections.
    • Mark A.
      • February 1, 1996
      • 299
      I have the latest 69 AIM, and the pictures really don"t do much good. I'll look around on the web. If anyone has a clear diagram, let me know. Thanks, Mark
      • Chris H.
        • April 1, 2000
        • 837
        Mark, here's a photo of my car if this helps. Chris
        • Mark A.
          • February 1, 1996
          • 299
          Chris,
          You have the same engine, and no power brakes, the same as mine. Could you possibly get me a closer picture of the fitting coming out of the manifold behind the rear carb? Also where does this hose connect to?
            • 15601
            Originally posted by Mark Albertus (27234)
            Chris,
            The car's vacuum system connects to that fitting (Headlights, wiper door and heater). if you look at Chris's picture, just to the left of the wiper motor is a gray disk (that is a check valve). Coming off of that to the outboard of the car is a smaller and a larger hose. What you can't see is toward the engine is a hose going to a white disk (a filter) and a hose form that goes to the fitting on the intake that you are asking about. I am sure there is a picture of all that in the AIM, but I don't have my AIMs here in the warm house. They are in the cold garage, so I can't give you a page to look at.
            • Chris H.
              • April 1, 2000
              • 837
              Mark, a couple more photos.
              • Mark A.
                • February 1, 1996
                • 299
                Thank you.
