1961 Corvette Inline Fuel Filter - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2036
    Did the base motor, 230HP single 4 barrel carburetor engine use an inline AC fuel filter before the carburetor?
    Helping a friend. Don't have an AIM.
    There is currently no filter there, and the fuel line is configured to go straight into the carb...with no provision for a filter.
  • Dennis C.
    • June 30, 2002
    • 884
    Re: 1961 Corvette Inline Fuel Filter
    A 230 hp '61 with a WCFB carburetor has a filter inlet on the carb. The filter is built in to the carburetor.
    • Chuck G.
      • May 31, 1982
      • 2036
      Thank you, Dennis. That's what I thought...
      I have looked online, and see that in 62, the fuel line from the pump comes straight up...a 90* fitting is placed...and a line then goes to an inline AC filter, and then to the carb.
      IF my buddy wants an inline filter, he'll have to get a new gas line...or bend/reconfigure/reflare his current line to accommodate the filter.
      • Frank D.
        • December 27, 2007
        • 2703
        Again the old British MIRA analysis of a brand new, base motor 61 is a great reference and here is a pic from that document. Indeed the WCFB has an internal sintered bronze fuel filter..
        • Chuck G.
          • May 31, 1982
          • 2036
          Thanks, Frank. I was going to EMail you, but IIRC, your 61 was a dual quad car.
          You know the car we're working on. It's a 61 real FI car with the original block... but it was "converted" to a 4 barrel MANY years ago.
          CS code.. 315 HP fuelie.
          Our goal is to get it running and driving well... Resto will likely come later on.
          • Mike E.
            • February 28, 1975
            • 5141
            Chuck,
            62 WCFB was configured like 61 with an inline filter. 62 300hp and 340hp had an AFB and the inline filter with glass bowl.
            Mike
            • Frank D.
              • December 27, 2007
              • 2703
              Yes mine was dual quad (which has an external glass bowl housing a filter, originally foam, repros are paper)
              You're working on a great car; I'm sure you'll get her humming...
              • Chuck G.
                • May 31, 1982
                • 2036
                Thanks again to all.
                • Steven B.
                  • June 30, 1982
                  • 4000
                  Perfect timing! Checked a friend's dad's original '61 230 HP with original engine and WCFb and found the original internal filter.
