Steering Wheel Crack - NCRS Discussion Boards
  • Robert G.
    • May 18, 2019
    • 56
    Hi, Hope you all had a nice Christmas/Hanukkah. I didn't spot any ads in the services section of "The Driveline" for steering wheel repair. I have a crack in mine ('66) which I would like to get repaired. Any recommendations?
    I also noticed that Eckler's sells a "Steering Wheel Restoration Kit" has anybody used that, and if so how were theresults?
    Happy New Year,
    Rob
    #65905
  • Gary C.
    Administrator
    • October 1, 1982
    • 17657
    Re: Steering Wheel Crack
    NCRS Richard Dunham restores steering wheels. You can look up Richard in the Members List and send him an email
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Robert G.
      • May 18, 2019
      • 56
      Thanks for your help and the lead
      • Tom D.
        • September 30, 1981
        • 2133
        Richard just called today. Write to me via email if you need more. He is focused on C1 wheels.
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
          • 11643
          Correct, he does not do 1966 woodgrain-style wheels.
          I think you could fix it with colored epoxy material. Whether you could get the actual appearance to match is an entirely different subject.
          I have used black, brown and grey epoxies for various repairs. Some are more visible than others.
          • Keith B.
            • September 15, 2014
            • 1582
            depending on how big the crack is you can fill it in with wood workers wax of the right color. I did this to my Chevelle plastic wood wheel over 10 years ago you can't tell
            • Robert G.
              • May 18, 2019
              • 56
              Keith,
              First thanks for answering my post. The crack, according to my tape measure is less than 1/16 of an inch
              Sending you a picture of it, do you think wood workers' was will work?
              Rob
              • Keith B.
                • 1582
                Yes I would give it a try if you can find some wax the same color. You might have to mix and make your own. I was fortunate at the time I worked in a furniture factory at the time in the finishing department and had some scraps of colors and one was just the right shade of brown. You wipe/rub it in then take a tac cloth to clean it up.
                • Keith W.
                  • June 30, 1998
                  • 375
                    • 11643
                    Originally posted by Keith Willcox (30641)
                    I notice that the POR kit described in the article is no longer available.
                    Similar epoxy products will work. However, I would be far more judicious in the application than shown in the article. Once epoxy is dry it can be extremely difficult to remove. I would fill the cracks just lower than level, and then use his paint trick to fill it in. Making "matching" paint like that was a good idea.
