1960-1962 EFI Converted "Rochester Fuel Injection" - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1718
    Posting as "Interesting" only. I didn't know you could do this!
    Below is the link to the Ebay auction.
    [B]-Coat this System, for even a better finish!
    As you can see, these Components are in Excellent-Condition! I make a Custom-Throttle Body Adapter out of 6061-T6 aluminum and Gasket to Mount the LS Throttle-Body to the Rodchester Intake Manifold, Eight Pico Fuel Injectors capable of Supporting over 600 HP, a New Fuel Distribution [B]Block w/Manifold Mounting Adapter, 8 90 Degree -3 Fuel Injector Fuel Line Adapters, 8 Custom High-Pressure Rubber Fuel Lines & Fittings, "New" Intake Mounting Studs, SS Nuts & Washers, 4-New Intake Plenum Gaskets, New Stainless Mounting Hardware, in other words you just need the Electronics! I have also provided the Distributor Spacers as well! Almost Any Brand of Electronics will provide Excellent Results
  • Mark E.
    • April 1, 1993
    • 4603
    Re: 1960-1962 EFI Converted "Rochester Fuel Injection"
    This could be a cool set up for a resto-mod that looks mostly original to the casual observer.
    I've known a few good mechanics who couldn't spell Chevrolet let alone construct a sentence. Maybe that's the case here.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Richard G.
      • July 31, 1984
      • 1718
      Yes, it very well could be the case.
      It may have been easier if I would have just corrected the spelling.
      I know if I didn't correct it or mention it. someone would have.
      Seems like a great resto idea.
      Rick
      • Jim L.
        • September 30, 1979
        • 1816
        Except for the doghouse and the adapter plate, there's nothing else left of the original FI unit!!!
