1960 front body mount inside support - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Has anyone found a replacement part number 3788313 and 3788314 inside body mount support for a 1960?
    Both of mine are unusable and need to be replaced.
    These are located inside behind each seat to the outside.
  • Ernie F.
    • March 31, 1975
    • 107
    Re: 1960 front body mount inside support
    Duane, I believe you have the wrong part number if this is the reinforcement behind the seat/door. 3188313 and 3188314 would be the correct number. The reproductions are replacements for 56-58 and correct for 59-62. https://willcoxcorvette.com/corvette...-2-piece-56-62
    • David H.
      • November 11, 2009
      • 777
      Thank you so much sir!
      • Gary C.
        Administrator
        • October 1, 1982
        • 17769
        David,
        Check with Vette Products, they make frames and parts from the original blueprints.
        Specialists in Quality Corvette Products. One of the largest inventories of new, used and restoration Corvette parts for 1953 thru 2003 Corvettes.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
