63 clutch pedal push rod - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    The AIM shows a washer at both the Z-bar (barrel swivel) engine bay side under the "G" clip and another at the cockpit pedalbracket where the other end of the rod goes on the shaft. I have only one "wave" washer - are these used on both ends or just one ? And if so, which end...and is the other washer on the other end just a flat one ?
    And does the washer in the engine bay go between the swivel and the Z-bar or between the "G" clip and Z-bar ?
  • Richard G.
    • July 31, 1984
    • 1718
    Re: 63 clutch pedal push rod
    Frank
    Best I can tell from the assembly manual a wave washer is used between the clutch rod and the pedal. It goes between the rod and the pedal bracket.
    On the lower end of the clutch rod it isn't as clear in the drawing. However, it clearly indicated, in the call out, the 3834560 washer (wave washer, I suspect) at the bottom end.
    Looks like you will need two of them. Be sure to insert the rod from the correct side. The G washer is on the inside, at the Z bar on the rod from the pedal. And the clutch rod enters the "Z" bar from the engine side. I believe the direction the clutch rod enters the "Z" is unique to the 63.
