67 key code for ignition. - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    I have my cylinder out and have searched the archives for the key code so I am taking this short cut and asking rather than looking for another 1/2 hour.
    I am on my way to the shop today and am going to look for the code so I can have the correct key made. I will look at what I have and check back in a while to see if I get answers.
    I have about 30 keys that fit and once in a while one works. I want to get it right.
    Seems to me that I used to look at the glove box lock, but from what I read it says the code is on the ignition cylinder? Going back to my days at Chevy there was a place to find the code.
    Also, what key operates what. Door, ignition, glove box, and tire lock?
    Dom
  • Gary B.
    • February 1, 1997
    • 7064
    Re: 67 key code for ignition.
    Dom,
    For '67, the "A" letter key operates the ignition and doors. The "B" letter key operates the glove box and tire lock. The Ign/Door key code should be stamped into the side of the ignition lock core (if it's original) and into the side of the door lock case.
    Gary
    • Daniel J.
      • July 29, 2007
      • 158
      Dom.
      There is a 4 digit key code "typically" stamped on the ignition key cylinder.
      One key operates both ignition & doors.
      The other key operates the glove box & spare tire lock.
      Dan
      • Domenic T.
        • January 29, 2010
        • 2452
        Gary& Daniel,
        Thanks, I'm off to look. Really appreciate saving me time.
        Dom
        • Frank H.
          • November 17, 2017
          • 44
          hi dom, i also have a '67 and just had keys made. the glove box lock tumbler has to be removed from it's housing to read
          the code.
          file:///C:/Users/fkhjr/Downloads/C2%...%20removal.pdf
          • Domenic T.
            • January 29, 2010
            • 2452
            Guys,
            Thanks. Had my head up my a??. Door locks and ignition all have same code! Guess all i need is to go to key shop? Hope all tumblers are good. 42 + K on car.
            Thanks for helping. Gary, did I do your comp years ago?
            Dom
            • John D.
              • June 30, 1991
              • 875
              I have this key cutter and code book I bought at a swap meet many years ago. I can cut you a key to the code and drop it in the mail if that will help.
              jd
              • Domenic T.
                • January 29, 2010
                • 2452
                John,
                Nice of you to offer. I might do that if I can't find a good key shop here.
                Dom
