63 power brake conversion - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2925
    #31
    Re: 63 power brake conversion
    Originally posted by Ronald Lovelace (50931)
    Frank, and others -
    What are you using to get a correct looking (and fitting) Power booster?
    What I understand the 64-67 has an angle that hits the hood?
    What about stamped in numbers and other details?
    63 is a one year only booster. #2574 is stamped on one of the tabs. Apparently it is not unusual to see passenger car units restamped with that number so be careful. The Master cylinder for non PB and PB cars is the same except for on PB cars they added a bleeder near the brake line entry.
    The MC cap has a thumb screw on non PB cars and the thumb screw is changed to a hex bolt on PB cars apparently to provide some additional clearance.
    • Ronald L.
      • October 18, 2009
      • 3248
      #32
      Hi Dave, thank you for the answer, the MC is available in varying degrees of correctness, but not having any luck on the booster, is it the angle that prevents the 64 from being used?
      More than curious what can be made to work, more correct than not...
      • Bob R.
        • June 30, 2002
        • 1595
        #33
        The 64 booster should be a functional unit for a 63 but the configuration/appearance is slightly different
        • Frank D.
          • December 27, 2007
          • 2703
          #34
          Frank, and others -
          I scored an original 63 booster and had it restored; I'm not sure other years will work.
          However Vern Frantz - a very smart guy on such topics (and passed just last Valentine's Day sadly), said that 63 passenger car boosters will work.
          • Bob R.
            • June 30, 2002
            • 1595
            #35
            63 passenger car boosters are the same as the Corvette boosters but have different part numbers. The difference is the mounting brackets, the fire walls are different on the cars so the mounting brackets are different. If you want to use a passenger car booster you will have to install the Corvette style mounting brackets. I think LI Corvette sells the brackets.
            • Frank D.
              • December 27, 2007
              • 2703
              #36
              Thanks for jogging my memory - that is exactly right, with a bracket swap the passenger boosters will fit and look original sans the part number.
              • Ronald L.
                • October 18, 2009
                • 3248
                #37
                appreciate the help!
                • Bob W.
                  • December 1, 1977
                  • 802
                  #38
                  Frank, Do you know what the numbers are that are stamped on the booster?
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    #39
                    I believe the number 2574 is on a tab extending from the outer circumference of the booster, look closely at these pictures:
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      #40
                      Yeah, lots of lookers at that one...
                      • Bob W.
                        • December 1, 1977
                        • 802
                        #41
                        Frank, thanks for the corvette # do you know the # for the pass car?
                        • Frank D.
                          • December 27, 2007
                          • 2703
                          #42
                          • Bob R.
                            • June 30, 2002
                            • 1595
                            #43
                            The passenger car booster is 2580
                            • Jack J.
                              • July 31, 2000
                              • 640
                              #44
                              Originally posted by Frank Dreano (48332)
                              Yes... The flag is bolted into the top hole, for 63 at least, all the vendors sell this piece.
                              Those sites claim it was used thru 67
                              • Bob W.
                                • December 1, 1977
                                • 802
                                #45
                                Bob, Thanks for your reply.
