How many gallons of coolant? 1967 big block - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    I have a new DeWitt aluminum radiator and plan on using the Zerex G-05 coolant. Ho many gallons will it take? It is a big block 390hp car.
  • Jim D.
    • 2885
    Re: How many gallons of coolant? 1967 big block
    My 65 big block took 3 gallons of G-05 and almost 3 gallons of distilled water. I believe the "official" capacity is listed at 22 Qts. but don't know if that includes the heater core.
      • 43273
      Dave------
      The cooling system capacity for a 1967 big block with heater is 23 quarts. Assuming that you have a DeWitts Direct Fit aluminum radiator and assuming that it has the same coolant capacity as the original radiator, that should be the capacity of your system.
        • 43273
        Jim-----
        22 quarts includes the heater core. 21 without.
        • Jim D.
          • 2885
          Thanks Joe. I'm running a DeWitt's direct fit but it's the larger HP series. That must be why mine took a bit more to fill.
